show isis neighbors
show isis neighbors {area area_name} {vlan vlan_name} {ipv4 | ipv6} {detail}
Description
This command displays information about neighbors and their adjacencies.
Syntax Description
area_name Specifies a router process for which to specify neighbor information. If you do not specify an IS-IS area, the software displays the neighbors in all areas.
vlan_name Specifies a VLAN for which to specify neighbor information.
ipv4 Displays only the neighbors that advertise the IPv4 protocol as supported.
ipv6 Displays only the neighbors that advertise the IPv6 protocol as supported.
detail Displays detailed information for IS-IS neighbors.
Default
N/A.
Usage Guidelines
If you do not specify either the ipv4 or the ipv6 keyword, this command displays all neighbors regardless of the supported protocol.
The following command displays IS-IS neighbor information for areax:
show isis neighbors area areax
Platform Availability
This command is available on platforms with a Premier license as described in the Switch Engine v33.1.1 Licensing Guide document.
